26-27 toy-t build
phillip-r-s
Nov 8, 2010
199
Ok I am finally going to start a build thread.
Here is the low down up till now, I bought two pretty rough model t bodies a tudor sedan and a coupe with an extra set of rear quarters along with I think six doors, all for $350 from a guy on the craigs.
I got an 85 Toyota with a 22re that didn't run for $400,which turned out that the computer had just come unhooked , olives it back in and it fired right.up thought the number three exhaust valve is stuck open.
Found a 63 ford front axle for $40, still need to find the exact bearings but the Toyota hubs were surprisingly close. Intact the inner bearing was dead on an the outer was only off by two millimeters. Also still need to design and have someone make a bracket for the brakes, but not to worried about that just yet.
Next is the front suspension and steering.
P.s. any suggestions, and yes even criticisms are appreciated, however please bear in mind that I am just a poor car lover. The key word being poor.
