This one was removed before I got it Im in the process of tring to determine if frame is good and square, I have seen alot of people eliminate the x but only after new trans, crossmember and front welded solid, they also cut off the front cross member witch I havnt seen anyone else do, but if it turns out I bad I have a spare! good titles to both...It will just turn into a 47 aero build
