49 KB IHC build
busman
Dec 29, 2007
147
Beloit, Kansas
Heres our new project. Its a 49 IHC KB. Starting with the frame 2x4x3/16, buggy spring front and back. Model a crossmember in the front homemade perch in
the rear. Tapered the front frame rails. Going with fourlink in rear still deciding on the front. Cab is rust free and pretty straight.
Ford explorer 8.8 rear end 3.73 posi. Super bell 4" drop axle with single leaf reverse eye spring. This is where were at now. Need to scavenge some more parts working towards a rolling chassis.
Heres some more progress. What do you think of the shackle angles on the rear spring. I preloaded the spring but it seemed to settle more than I wanted it to.
Motor and trans mounted. Front end and hairpins tacked in place. Found some modern wheels I like, that look similar to an artillery wheel pattern. I think they will look good when they are cleaned up.
I cut the tubing to mach a model a frame then clamped the tubing back together and welded it up. I cut out the red section in the picture.
Dont plan on chopping it. Yes I did build the motor mounts and I will attach a picture.
Yeah... really nice work & it's definitely comin' together! U'll be finished B4 too long now! Dang... I better get back out in the garage!!! :eek:
Got the bed and grill mocked up. Frame horns welded on. coming together little by little.
