50 inch brake
Bonehead
May 11, 2007
12,258
Fruita, Colorado
I needed to brake a sheet of 1/4 aluminum, so I built this brake, and it worked well. I used two grader blades welded together and dropped into a piece of 1/2 inch x1-1/2 x 1-1/2, with a 20 ton jack.
Nice job! I was thinking of building a press brake but decided not. Did you see the brake I made? it is 30 or 32" works well. I bent a piece of 3/16" in it once and was surprised it worked really well. It is pictured in the homemade tools thread.
[clI like the way you rounded the ends of the support bar too [cl
The next upgrade would be an air over hydraulic bottle jack :cool:
