darkk
BBC 400 hp +/- nothing real radical. Car is Pro Streeted. Has a Holley 110 gph pump. New filter. 3/8" line to motor and back to tank. No kinks.Pressure set to 6 lbs. Runs great for a while then just dies. No sputtering or on/off like electrical,no backfires. Just dies like ran out of fuel. If I restart immediately, the motor will just die out again. If I let it set for as little as 2 minutes, it will fire and run good again. It doesn't do it with regularity. But it is often enough to be very very annoying. Possible fuel pump issue? Any ideas?
