Thought I'd put this here instead of burying it in my build thread....if no good I can repost.
So as you may remember I installed the bear claws in my doors....they work fantastic. I bought some plastic door actuators that trip the bear claws very easily. Great.... until last few days.
I needed to install some door mechanisms so I can open the doors from inside so I bought these. https://www.summitracing.com/parts/GMK-4020443671P
The stocks were very worn, had lots of wobble and no return spring....you know whats coming, yes?
Well the return spring is too much for the actuator to pull. I think they only
produce 10 pounds of pull. Can I get something stronger? Hit the spring with some heat....maybe weaken it some. What to do?
I need a roll of gauze for all the cuts on my forearms.....arrrgg
