Electric water pumps
darkk
Aug 14, 2010
274
Willimantic,Ct.
Are there any good electric water pumps available. I know years ago they weren't really good for a daily driver. Has that changed?
There are... racers use them & I've seen them street cars but they're usually pretty expensive. Try Jegs!
Yep, do as Tripper said, also try Summit. They worked wonders for the drag cars....and alot of folks started running them on the street with their blowers and all out mountain motors....with good luck.
The MFG'ers saw the writting on the walls....so they started making the street version. They're not super expensive.....about 150 to 200.... or you can mount a Metzler kit....which is a elect. motor and belt to drive your stock pump.
In the street cars and buckets.....its a good cooling system when you got elect. fans cooling your radiator and a elect. coolant pump....frees up parasitic power loss....
:cool:
Meziere pumps are about the best out there. A ton of people run them on the street without issue. Some are even remote moutable and have remote thermostats in them.
