I "refreshed" my first engine (early 70's dodge 360) by pulling it all apart, cleaning everything, replacing gaskets, and rebuilding the carb.
To my surprise, it actually started and I was running only water because I didn't want to dump anti-freeze everywhere just in case, and luckily I did because my header bolts run into the cooling passages and it was leaking all over every time i tried to re-install them and every time I had to take them on and off I would have had to drain the coolant and make a mess.
My question is: I am still not really done with my headers, I want to turn the straight pipes into lakes headers so I can bolt on mufflers when I have to so while I am working on that is it OK to let is sit empty for a few months (yes, I am slow) after running only water, or is there water sitting in there that is rusting everything out?
