Erratic Oil Pressure Solved!!! I think...
bob w
Jan 2, 2008
13,207
Stillwater, MN
You may remember my thread about the erratic oil pressure problem with Big Dodge.
One of the RRR members suggested adding a couple quarts of oil to see if the pickup had fallen off the oil pump. I did just that a week ago. When I tried to start the engine it wouldn't turn over and terrible noises came from it as it made a few jerky attempts to turn over. I figured that the pickup or maybe even the pump had broken free and got caught up in a crank counterweight.
Today I cut the engine crossmember out of the way and dropped the pan. Darn, everything looked perfect. The pickup was welded to the pump in the right position. The pump internals looked like new. I put the remote starter button on and turned the engine over with the pan off. A few drops of water dripped down the cylinders! Holy cow! I thought it had a cracked block or at least blown head gaskets. 6 plugs were wet with water when I pulled them. I spun the engine over and water sprayed out the cylinders, then stopped. So, most likely no cracks or blown gaskets. Big Dodge had sat outside for a few weeks, and apparently the air cleaner acted like a funnel gathering rainwater and letting it run down the center hole in to the cylinders. So when I tried to start it after adding the oil, it was hydrolocked.
This 350 SBC came out of Leo's van and was rebuilt and had very few miles on it. I took the engine out of the van, set it in the corner and put it in Big Dodge. Since the dipstick and tube in the van were 4 feet long, I had thrown them away. I didn't have a SBC dipstick and tube so I grabbed a 292 Chev 6 cyl dipstick and stuck it directly into the hole in the block. When I pulled it out it showed oil up about 2 inches. I assumed this would be the "full" mark on the substitute dipstick.
As I continued to investigate, I realized the dipstick reached the bottom of the pan and what I had taken for the "full" level was really no more than 1-1/2 quarts of oil in the pan, maybe less! All this happened because I assumed the engine was full when I took it out of the van. And, I didn't change oil when I put it in the Dodge. I planned to change oil after a few short neighborhood trips. Never got that far. The problem would have been discovered with the addition of the 2 quarts of oil as suggested by the RRR member,but the water in the cylinders problem stiffled that attempt.
I haven't put everything back together so this isn't for sure. But the erratic oil pressure is the same behavior that I had in my youth with oil sucking beaters that I would let run too low. So, I'm quite sure this it it.
I am ready to turn in my RRR membership for such slipshod hot rod building efforts. Hoping you all will give me another chance, however!
Moral of the story: NEVER ASSUME ANYTHING, like the crankcase being full. CHECK EVERYTHING and DON"T LEAVE 'EM OUT IN THE RAIN!
Well Bob. That turned into a complicated repair for a simple problem :D. Imagine that. A low/fluxuating oil pressure reading actually meant that the car was low on oil. Who woulda thunk it:p. On a more serious note, I hope the hydro-lock didn't bend a rod or anything.
Embarassing isn't it? It goes to prove you're never too old to screw up! Since the engine didn't start with the rainwater in the cylinders, I'm thinking the starter motor isn't strong enough to bend a rod. Any experienced guys out there have an opinion?
Admit it!!!
Bob,
Come on man... admit it!!! You were tryin' to see if the Dodge would run on water like they're claimin' in some of the mags!!! BUSTED!!! :D:D:D
Well, Big Dodge is back together and the oil pressure is fine. The hydrolock event didn't hurt anything either. I changed the accelerator pump linkage setting and most of the off idle hesitation is gone. So, the comedy of errors didn't cause any damage. Got lucky this time...
Boy, did you get lucky! :p I had my sbc hydrolock and I bent half my pushrods. Went to replace the pushrods and one fell into the engine. Had to pull the intake. What a pain. :( Float stuck open on the tripower and filled the cylinders with gas.
