Ford 302 question.
DJ3100
Sep 4, 2009
1,899
Chandler, Arizona
What do I do with the water pump port for the heater hose and the intake manifold heater port? Can I plug them both or do they need to be connected to each other?
If plugged - how do you plug the tube on the water pump?
If connected - It looks like I need an L shaped hose about 3/4 diameter, where do I get that?
Anyone got photos of their solution on an SBF?
Thanks
I have done it a lot. The intake you can plug it or use it for the water temp.
The one on the water pump. I use the heater core caps you can find in the help rack in most auto parts store. They usually have two in the package. Just put it on with a hose clamp.
I never had any issues.
i've even seen them run with a short piece of hose with a big bolt stuck in the hose w/ a hose clamp on it.......redneck-styling at an affordable price:D
302 by-pass
I too have a 302, one of the outlets can be capped and the other needs to hooked up to the thermostat housing the little outlet next to the big radiator hose the by-pass hose can be bought at any parts store. hope this helps
Wow, thanks guys. I like the idea of capping the intake and the water pump port (I already got the by-pass hose for the one that goes to the thermostat).
The heater core caps sound like the answer.
Glad to hear it has been done with no problems.
I just looked at the rubber caps I have hanging on the wall in the garage. There in a red help package and 1 said water pump cap and the other said heater cap.
Thanks. I looked at Manny M & J's today and they didn't have them. I'll check out AZ and O'R.
