DJ3100
Many electrical problems in older cars are the result of poor ground connections.
I run ground wires for all the circuits and tie the ground back to the negative terminal on the battery, rather than grounding to the frame. It gets to be an issue about how to connect all those ground wires to each other.
Here's a solution I found at the electrical supply house. Just plug the stripped wires into the connector. They work on stranded wire 12 ga. and smaller. The other photo is my headlight support where the ground splits to the other headlight.
