Help. Need info on electric fuel pump hookup
thanksbe2
Jan 8, 2016
18
Ok, Supernoob here. I have a stripped '02 Blazer Xtreme frame. It still has the fuel tank and what looks like an external electric fuel pump in place. The motor that was on the frame was a 4.3 V6.
I bought a '92 Vortec 305 which has had the intake replaced and a carb installed. The guy had it running in an 80's truck with a electric fuel pump hooked up to it.
Is it possible to hook up fuel delivery a different/simpler way? Mechanical is apparently not an option on a Vortec.
I have no wiring harness with the frame. How do I hook up the fuel pump electrically? Does it require a computer to control the flow or on/off? Assume I know nothing about this because I do know nothing about this.
Thanks!
Yep, you can use a Holley blue pump with a regulator.
Or you can use one of those el cheapo electric pumps with no regulator.
I'm a big fan of those cube style pumps. Very quiet, with good delivery. I ran one on a hot 302 with a big cam, 650 4bbl and headers and never had a fuel delivery problem, even at high RPM's. Running one right now on my Lincoln, just bought a low pressure unit to replace the failed pump on my truck APU.
