Help with engine decode please
51 ford
Active member
Jan 27, 2008
35
Idaho
Can someone give me a link or tell me how I go about getting an engine decoded? I have two chevy engines I need to decode. I tried FTE but their decoder said they were not valid numbers, I wonder if theirs will only decode ford numbers.
You tried putting Chevy #'s into FTE's decoder?!?! What were you thinking! Hope their servers didn't shut down... :D
Do a Google search for "chevy motor decode" - all sorts of sites come up.
Thanks Gastrick. The trouble I am having is everything is based on the casting #s instead of the stamped block #s. I've been to a couple different sites. One says I have a '69-'79 350 car/truck/vette, another one says I have a '69 327 from a Z-28. I have two engines, If anyone can help here are the #'s ---- Both are casted as 3970010, One stamped block # is V1006TYX, the other one is V1005TWY. Anyone?????
The prefix portion of the ID code tells you the assembly plant code, and the engine's production date. The suffix portion tells you the original model year / engine / transmission / car combination when it went down the assembly line.
Engine ID Code Example: V0101CLJ - (V = Plant, 01 = Month, 01 = Day, CLJ = Engine Suffix Code)
Another example: T0830CTY - (T = Tonawanda, 08 = August, 30 = 30th day, CTY = 1970 396 Camaro, 375 hp, 11.0:1, TH400)
Ok go here:
http://www.nastyz28.com/sbchevy/sblock.php
I wish I had my book handy. the 3970010 is a car/truck/vette 4 bolt main I believe. Not sure though. Well maybe 99%
if it was a DZ 302 I would send that my way[cl
Hows this:
V1006TYZ
V1006=FLINT,MI OCTOBER 6th
RPO YEAR CID appl VIN HP BBLS Body/Comments
TYZ 1975 350 conv.cab L LS9 165 4 C-10 to 2500
V1005TWY
V1005=FLINT,MI OCTOBER 5th
TYW 1975 350 conv.cab L LS9 165 4 C-10 to 2500
This is all I could Find, I hope this Helps....;)
Sorry On the last line TWY should be:
RPO FY CID appl VIN HP BBLS Body/Comments
TWY 1978 350 conv.cab L LS9 165 4 C-20 & 2500
Sorry I copied the wrong Line.[S :confused:
Hey guys thanks for the help. Grumpy I finally found that same info on NastyZ28. Took me a while but I found it. Now I've gotta get to rebuilding.[cl
