lowbudget50
- Joined
- Sep 23, 2012
- Messages
- 5,833
It's been a slow start to winter here in North Western Colorado. But today it started dumping. Got about 4" during the day, plowed around 5pm went back to work @ 7pm and then it snowed another 5" or 6" by 10pm.. Wonder how much we'll get by morning.
It warmed up to -7*C or 20*F now and it's raining. the droplets are big enough that I could hear them hitting the snow, from inside the house. This was the most scary time to be out there trucking. The rain freezes onto the road no matter what the road is made of, and the ice is clear so you don't see it and very slippery. Most times when you spin out on this surface you bail out quickly right after you set all of your brake on, and you realize that you can't stand up on the road. You get over to your truck a quickly as possible, [luckily you were smart enough to put your back-up lights on way back there] and hang on to it so you can stand up. Did I mention that all this time your truck is sliding back down the hill in the dark, loaded? Anyhow, you grab a set of chains and throw them under a set of drive wheels. That slows the truck down. Now throw another set under the other side drives. Now the truck has stopped. That's probably your best set of triple railers down jambed into the ground. Throw your other set of triples on the other driver wheels, now and do them up the best you can, with the truck creaking backwards slowly, in the dark. You probably can't lift off with only one set of chains on so you have to back over your 'thrown under' chains and then try and stop your truck again. Retrieve your good chains and throw them on. This is a good time to put your steering chain on too. Now, try to lift off and head for the middle of the road and straddle the crown so you don't slide sideways into the ditch even if you're moving.
Right now it's -37C* or -30F*.
