Kechi 1949 3100 4.3 4L60e
joedoh
Oct 5, 2015
1,725
doodah ks
well I still dont have any news and idle hands are the devils playthings, so I popped on craigslist to find some more trucks.
this is all that was available for what I was looking for, all of the V6 longbeds were seriously overpriced and none of the shortbeds were V6. I wanted to stay in the 98-03 range, and this was the rustiest body I have ever seen but man did it run and drive like brand new. this is what $1000 will get you.
attachment.php
if you cut the framerails right behind the core support mounts you can have the front clip off in one piece in less than 45 minutes, followed by the bed, then pushing it in to strip the interior because its cold outside.
attachment.php
attachment.php
attachment.php
i didnt break my t47 taking the seat out, this is a good sign!
attachment.php
I got the HVAC off the firewall and all the pedals. quick tip: you can unbolt the whole AC portion of the system from the firewall and leave it charged until you are ready to put it back on.
attachment.php
attachment.php
attachment.php
then pull the cab with some help from my friend Ron who stopped by at the perfect time.
attachment.php
while I was outside, I chopped up the bed to get the floor I wanted.
attachment.php
picture limit, more to come.
the truck had a slight vibration at highway speeds and I figured it was the double cardan driveshaft, but it might have just been mud.
attachment.php
after pressure washing about a hundred pounds of mud off of everything including in the u joints, i rolled it in to start pulling the motor.
attachment.php
the truck was the quietest thing I had ever driven, the road noise was louder than the engine, here is why. that is one bad cat.
attachment.php
I loaded up everything for scrap that didnt sell right away and hauled it away. the craigslist is glutted with s10 parts, everyone is taking these apart.
attachment.php
pulled the motor to start the frame shortening and new engine mounts.
attachment.php
attachment.php
i separated the frame at the joint and took out 6" to give me a 117" wheelbase.
attachment.php
attachment.php
I would have had it tacked back together but there are two spots to trim. so maybe tomorrow.
I also still have to go see Wayne and make a deal on those cabs he has.
got the frame welded up last week, total time is about 3 hours, spread over 3 days. so 3 days, right? haha.
attachment.php
tracked down wayne, he is fine. made a deal on 4 cabs and three front ends :D
picked up kechi, he is fine too.
attachment.php
attachment.php
he had about 200 lbs of kansas farmland packed in the floors and seat, I just tipped him on his nose to clean most of it.
attachment.php
power washing in the rain took care of the rest.
attachment.php
moved the motor mounts back 8.75 inches.
attachment.php
attachment.php
http://ratrodsrule.com/forum/attachment.php?attachmentid=147193&stc=1&d=1552441353
attachment.php
attachment.php
picked up all the parts I needed at the swap meet last weekend, aprons, a rad support, front bumper. got some rear fenders from a local guy too.
more to come, maybe the motor will be back in tomorrow.
How did you come up with the measurement for the motor mounts, they look a bit far back if you're going to be running front fenders? [P
thanks guys, I have some new ideas to try on this one. stay tuned.
its the 4.3, the motor mount is in the middle of the engine, a v8 is further forward. with a v8 the move would only need to be 5-6 inches but on a v6, 8.75 inches rearward move puts the oil pressure sender plug 1/2 inch off the firewall. its a tight fit, putting everything under the hood, but it all fits.
thats an early picture, before I mounted the PCM and the battery in there :D
I decided to do the trans crossmember with the engine out. still working on the best way.
in this pic you can see the offset GM used to the passenger side, with the edge of the straightedge centered on the suspension crossmember, the 1/2" offset is visible, you can make out the trans mount hole to the left of the edge.
attachment.php
next, I happened to catch a view of a 2.2 crossmember on craigslist and it was way back on the passenger side.
I measured and that worked out perfect, I built a flange on the passenger side to weld the mount to, and sectioned the mount a couple inches on both sides (the frame gets narrower in that section). the drivers side I cut a piece of 11 ga and bent the ends down, a much faster way than the three piece way I used to do it. still need to drill two holes but its all in there.
attachment.php
attachment.php
while my welds were cooling I popped out all the side plates for the cab mounts.
attachment.php
I powerwashed the frame and wire brushed all the hard to get areas that would be hard to get with the engine in, and shot some black.
attachment.php
tomorrow I will get the engine plopped back on its mounts and start on the firewall mods. I washed the cab again and its BLUE. I have some blue parts out back, have to see what I can do here.
