joehalford01
'Vette brake specialist!
I pretty much finished the battery install on my truck. It was originally behind the cab in a tool box. I had to order a stock style tray. I couldn't find a negative cable locally that was long enough to run it nice and clean like i wanted so this is a temporary set-up. I will probably order one soon from summit.
This is where i attached the negative cable for now, Is there a main grounding strap on these motors or do they ground via the motor mounts? I didn't see one but then again, i didn't look that hard. I've been pretty busy.
(ignore that red wire, it's gone now)
