lowbudget50
- Joined
- Sep 23, 2012
- Messages
- 5,830
Love those motors!!! [cl
Did you use the alignment tool for the front and rear crankshaft seals?
The first few I put together I got away with one but had to go back and redo two of them to stop the oil leaks.
Yaaa on the oil
Booo on the tranny
https://www.amazon.com/Front-Cover-Billet-Alignment-Engines/dp/B088W435KX
Did you use an oil pickup tube o-ring that you had to use a little force to push it into the oil pump or did it slip right in?
I've had this issue and found out I had used too small of an o-ring out of the gasket kit.
That sucks man... I hope you will find the problem before you have to buy a hemi.
