narrow axle in front wider in the rear
motomech
Mr. Willys
May 17, 2007
562
mesa,arizona
my rear axle is about 6 inches wider than my front axle resulting in 3 inches wider on each side will this be a problem im gonna use the same wheels all around (stock 15x7 steel wheels) will this cause any alignment problems.
or handling,uneven tire wear,dizzyness or upset stomach?:eek:
sweeeet i hope to install it this week i was kinda worried when i pulled it from the doner car i looked at it and said "wow this thing looks kinda wide"
glad to know it will be ok thanks don:D
Just like the other guys said, you will be fine with the setup.
Just as a useless side note, early dragsters were built with a much wider front track than the rear. It was thought that this configuration offered stability to the (then) shorter wheelbase dragsters.
