Rat Rod Mac
New member
- Joined
- Aug 7, 2009
- Messages
- 2
New here and need help. I have a 283 in my Rat and it seems to be hesitating or maybe missing from idle until it comes under load then seems to smooth out some. I have a manuel choke Edelbrock 600 on it. ( If I had to do over I would have gone with a 500 cfm ). Anyway I was wondering if I give you guys the specs. if you could tell me what rods and jets to use. At least get me in the ballpark. OK, here's what I got,,,,, 283 Chevy, flat top pistons, 327-350 Corvette intake, the 600 carb. blockhugger headers, running 5 lbs. fuel pressure, cam is 214 lift, 447 duration hydraulic, point distributor converted to electronic with a Pertronic unit, 305 Chevy heads, 350 tranny and 325 rearend gears. Well thats about it. Someone told me you can't go by the color of the plugs anymore due to the gas we now have. If this is true or not, I don't know, but the plugs almost have a pink color to them. The carb. is set up now with these,, Primary Jet .095,, Secondary Jet .092 and the needle .073 x .047. Once again any and all suggestions are welcomed. Thanks in advance. Rat Rod Mac
