BEARKRAFT
I went to change out my exhaust manifold gaskets on the Dart tonight and when I removed the rear bolt on the passenger side manifold, it started pouring water out of the bolt hole. When I had it running, it was not smoking or steaming out of the exhaust and there were no leaks anywhere. There were no signs of water in the exhaust itself, just coming from the bolt hole when the bolt was removed. Probably lost a 1/2 gallon out of it before it stopped. Where can the water be coming from?????? Head Gasket?? Cracked Head?? Does anyone have any ideas????
Bear
Bear
