Proper use of tools
RoddingRon
A man in his natural habitat....a Studebaker
Dec 8, 2007
1,626
Lehighton,PA
this was sent to me from a friend....not sure where he found it, but credit to the original genius who thought this up
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light . Also removes fingerprints and hardearned calluses from fingers in about the time it takes you to say, 'Oh sh--!'
PLIERS: Used to round off bolt heads. Sometimes used in the creation of bloodblisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXY- ACETYLENE
TORCH: Used almost entirely for lighting various flammable objects in your shop on fire Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
HYDRAULIC FLOOR
JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes , trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good
aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE
HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS
SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening oldstyle paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT
SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into nonremovable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER : A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacentthe object we are trying to hit.
UTILITY KNIFE: Used to open and slice throughthe contents of cardboard cartons
delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON-OF-A-B****H TOOL: Any handy tool that you grab and throw across the garage while yelling 'Son of a B****H!' at the top of your lungs. It is also, most often, the next tool that you will need.
Lately I seem to have a whole drawer full of those
SON-OF-A-B****H TOOLS....... seems as of late, I can't do a darn thing right.... had to just walk away for a while to collect my thoughts and get back on track..... too much crap going on at home.... not enough space or time to go into any of it..... but.. this too shall pass....
