Question about fuel filters
bruno
Crusty Rusty Old Rat Rodder!
Jan 27, 2010
2,216
harrodsburg ky
From the tank to the carbs I will be running a fuel shut off valve, filter, carter 4070 electric pump, filter, holley pressure regulator then Stromberg 97s. What micron filters should I run. I heard the filter between the tank and the pump could ruin the pump if it is to restrictive. Is their any truth in that?
Thanks
Pre filter should be a 100 micron and the filter to the carb should be a 40 micron.
The lower the number the more filtering you have.
