rat-on
I'm installing an external trans cooler behind the radiator and I need to know the ATF direction of flow. On the cooler line fittings screwed into the side of the tranny, which fitting is supply and return. There is an upper fitting and a lower fitting. My Rat does not run yet to find out. Thanks.
