Red wagon pedal car
NICE [cl[cl[cl
Thank you, sir!
I was all excited to get the axles really going, but we had a pretty bad storm on Thursday & part of the fallout was that the bearing shop I went to didn't have any power...which means the credit card machine didn't work. Hopefully they're up & running on Monday or Tuesday. That way I can see how high it'll be with the front axle on & determine how much drop to build into the rear axle.
http://ksn.com/2015/04/03/storms-leave-widespread-power-outages-in-wichita-area/
-Chaz
coast to drive conversion
I finished up my spokes & got one of my coast wheels converted to a drive wheel before being called in last night.
Hopefully I can get the other taken care of tonight & start working on where I'm going to mount the front axle.
-Chaz
-Chaz
I see what you did there... :D
Neither the first, nor the last
My axle stock is hot rolled & therefore is slightly larger than it's advertised 5/8". Since the bearings in the pillow blocks are precision machined, I had to do some ghetto machining. The first pic is of my success with my redneck lathe (and wishing I had a real one along with the skills to use it).
Then, I did a rough mockup on the bench & mounted the pan to the frame using the original hardware.
Then I transferred it to the floor & tried out some mounting locations for the axle. It's surprisingly long & I had to sit forward in the pan & move the axle back to make sure I could reach the virtual pedals & not too far back so that my feet wouldn't hit the pan.
With the mounting location for the front axle pretty firm I put it back on the table & converted the second wheel from coast to drive.
I grabbed the parts that I need to get mounted when I left this morning. Hopefully the farm store on my way home has all the different hardware I need.
-Chaz
