donsrods
It was too much to take seeing Blue and all of you guys building your trucks, so I started doing some things to my '39 Dodge pickup again. When I left of to start building my 23 T it was pretty far along. The frame is done, the engine is rebuilt and installed, the front suspension is pretty wrapped up, as is the S10 rear.
We chopped the top a while back and a couple of Xmas' ago Dan surprised me by doing my cab subframe for me. I still have lots of body work to do, including cutting the window frames down on the doors and trimming the bottom off of the cab ,
I'm running a 30 over 394 Olds with a mild cam, flattop pistons, and an aluminum intake with 3 rochester carbs. The rear end is set up with a three bar suspension setup and coil overs. Originally I had the slicks on it that I ended up putting on my T, so I am going to have to order some new wheels and tires from Coker. I am not going to use the slicks again because I plan on driving this one pretty much every day and I can't afford to be spending $260 per tire very often. I will just put some 8:20 x 15's on the back and use the 5:60's that I have already on it on the front.
Here are some pictures of where I left off a year and a half ago.
