blacksheep
Well folks, I now have in my shop a 27 T bucket all steel body. Doors function, but needs some sheet metal work. My plan is to build a truck. ,Not the typical shorty type either. My plan is to buils it with a 5 ' bed on it, and slammed to the ground. I have the front axle from a 39 I believe, and a 10 bolt Camaro posi rear end, with buggy spring suspension. I'm going to attempt a unibody design , incorperating the cab with the bed as one bolt down unit. Center to center on the axles will be right at 13 1/2 feet. I took delivery on a freshly built mild 289 with a C4 behind it. I'll post photos as I go along. Anyone know where I can find some wire wheels on 4 3/4 bolt pattern?
