Willowbilly3
A *real* tin magnet
I wanted something for the 260, not too much like the 2x4s you can find and not the $$ of the new 3x2 set ups. I has looked at the efi lower but the conversions were still out of budget so I did this;
freeby 302 efi lower (I had to remove it)
Friendly local machinist hogged it out for free too.
Then add a couple of the old pickup truck coolant spacers. I will plumb them in. Now my plan was to just weld them on but free advice from free machist is to make a plate to screw to the plenum that the carbs can be bolted to.
Then I got another 63 260 carb (you could use 500 holleys if you wanted)
I will also use pickup truck carbs to donate the required manual choke parts.
Right now I am less than $40 out of pocket for my homemade inline 4 bbl. Autolite. I figure with kits, welding, linkage ect less than $200 to have it up and running
Whatcha think?
Whatcha think?
