busman
Last weekend I picked up an 283 sbc. The owner did not know much about the motor. I have another 283 sitting in the shop but two cyl are a little rough so I was hoping to find a better block. I also have a fresh forged 283 crank sitting on the shelf. We got the new motor home and started to tear it down. Took the heads off cylinders look good no ring ridge can still see hone marks in cyl. Got the pan off and found that someone had balanced the rotating assy.(crank, rods, pistons). This is an old balance job where they welded beads on the crank to add weight. It looks clean enough but not like they do today. The story I was told is that the motor was built early 70s and was in an MG midget. The guy I bought the motor from ended up with the car and pulled the motor out to run a 350.The motor looks good just needs freshened up. Would you just freshen up this motor or build one using fresh crank and new pistons.
