work begins on 39 chevy.
finished bolting in the seats .just set the timing by ear re checked the float level.I was closin the shop doors to go on its maiden voyage when my kids show up we all pile in and took off on about a 20 mile ride .the only problem was as small bit of tire rub on the rear tire because of the worn out old springs the right rear spring has part of a leaf cut off. an old drag racing trick this car was a suposidly a drag car some time in the 60's. I may have to put in the new suspension I have sooner than later ,if I want carry any pass. that is kind of why we got a sedan. the engine got a little warm it is a new engine still seating rings. It was a great first drive .
running boards
after driving I realize gotta have running boards. I have some steel ones but they are ate up. would take alot to make them right. I am a furniture maker by trade and have had several people sugjest I make some out of wood. well that is what I'm going to do. will use exterior grade sign board. will look like steel after filled smoothed and painted.
Were your feet draggin??? LOL
Seriously, why do you "have" to have them?? I thought it looked pretty darn nice like it was...JMHO.... the ones you've made up look cool but was just wondering why it's a must....nosey I guess......must be this job....makes ya ask a lot of questions....lol
I'm guessing maybe the rocks hitting the front edge of the rear fender?
Great looking car btw! And cool idea on the running boards, definitely putting in your own twist to the build
just the little ive driven already chips in rear fenders.yeh it looks cool with out, will look even better with them and protect the sides of the car.
what do you mean , must be this job ....makes ya ask a lot of questions ?
He's a cop. (A nice one).
Is exterior grade sign board plywood? What is different about it? It looks heavy and dense.
It running boards look excellent.
Is that the plywood that has the resin coated paper on the surface? I used some to make some trim pieces on a patio I built for a customer and that stuff held up great!
ok a cop that makes since. yes it is ply wood. more thinner layers, exterior grade glue, flat very dense outer layer takes paint well and will accept auto finishes.
Sorry Harley Rider.....thought most everyone knew my job...
I didn't think about the stones flying....that would be a good reason....looks like you've got the right ideas and the right materials....cool [cl Sorry for the confusion.....thanks BobW...you're an alright fella too...:D
got the running boards on .I ran out of the paint I used on the body I had some semi gloss sprayed that on . was'nt sure what that would look like I think it turn out alright.
Gotta Say.......Not bad.....!!
Look really good..... a lot better than I had in my minds eye.....I think you made the right decision....[cl
pin striping
got some pin striping last night.
new rear suspension
after driving some more decided to go ahead and change out the worn out leaf springs. I had already bought a chassis enginering suspension kit.pulled the rear end and found it had 2:56 gears that just wasnt going to work. so we decided to change them out for some 3:42 gears and a posi . I had never rebuilt a rear end .bought a set of Richmond gears, they came with good instructions . with that and some advise from a friend it went well.
