Model A extended cab
Ordered torque converter and flex plate today. 4 weeks out, but that means I have time to get the rest ready!
Wiring continues. Main fuse panel installed and power wire ran to feed it. Jumped lighting,aux fuse box and fuel pump power out.
We have signs of life!
"It lives!!!!" LOL
View from the back looks wicked- and you sure got the headlights right. Would like to eventually see a night outside pick of those.
Keep on truckin! [cl
[P[P[P
More work has been done. Brakes are plumbed, it has been started and all the wiring is done. Going to the tuner after the 4th. It is running super rich and shoots good fire out the pipes!!!
The cooling system needs finished and the top chopped. Its getting g close
Chop chop' 2" off the top!
Pretty sure i read somewhere by lip Jack and straps were the only way to align your model A Body Lines
Got rat rod tonight, had to build some fancy pipe 90s for the upper radiator hose. I still need to tap the steam ports into the 90. Then it can be filled all the way up with coolant. Also got the transmission dip stick mounted and the engine dip stick installed. Finished mounting the dimmer switch and the head light switch. Getting closer
Steam port line finished, steering spacer being made, dash wired. Still working away!
Steering is 100% done now. Front and rear axles are tight., key switch and dash are installed and wired. Battery is tied down. Getting closer. Going to the tuner on friday!
