BBT showed up last night with a bunch of front end parts for me. I replaced the front spring with 29" reversed eye one, new shackles and spring perches and lower shock mounts, rereamed the steering arms and put in the new tie rod. I found out that I need to make a spacer for the front spring clamps.
I also got the hubs, rotors and disc brake kit for the front.
I also need to shorten the wishbone mounts.
I did get the box fit to the frame. I need to drill some holes to fasten it to the frame, but it sits down pretty good. I have the firewall marked for cutting to channel it over the frame but I decided to let my friend with his new plasma cutter do the honors. Those things really work slick.
