My '64 Rambler wagon build!
Yep... slam, bam, thank you ma'am! Only putting bags on the front for now & will be posting progress! These cars have a truncated front suspension that is a PITA & bagging it solves several issues!
Started mocking up the Firestone air bags & it was like it was meant to be! This picture is with the car jacked up but when I lower it where the car will end up it is dang near a perfect fit. Just has a lil alignment issue but I'll straighten that out... no prob! I made a plate that the bottom of the bag will attach to & that will attach to the bottom part with 5 bolts/nuts. I should be done with this side tomorrow & move on to the other side! Does that make sense?
I cut out a circular plate to attach the air bag to the lower part of the suspension. Onward through the fog!
