offroadrolls
Not related to cars, if it was, I'd know what to do.
I'm wiring up a float switch in a cistern to run a 1 hp shallow well pump. The float switch uses a piggyback plug that plugs into a 120 VAC outlet and then the pump plugs into it. My problem is the float switch is only rated to run a 1/2 hp pump. If it was a car, I'd use a relay..... simple.
Any electricians on the forum that know what I'd need to accomplish this or is there such a thing?
