deerchooper
- Joined
- Apr 3, 2010
- Messages
- 744
looks great.
all most there
all most there
The frame came out great! [cl
Are the rails parallel or do they widen as they go towards the rear?
Looking GREAT!!! Love the visor!!! I have a couple antique "2 man" saws... I'm planning on using one of them for a visor. I guess great minds think alike...
Looks GREAT!!! Looks to be Case equipment seats?
Everything is coming along nicely. Cool visor.
like the visor alot. i also like how you put db in there.
you want about 7 degrees of positive (leaning back) caster on the front axle. you can do this by putting an angle finder on the kingpin area and leaning the axle back (or dropping the radius rods) untill you get about 7 deg. I would say you will get about 1 1/2"-2" of drop when the weight of the engine squats the front end. If you have the ride height of the frame where you want it then set your axle, caster and radius rods to where you want it. Then figure out where you want your spring mount afterwards. That way when the axle rotates back to the 7 degrees your spring will move back as well and you wont get into any spring bind. you can either lift your frame 2" from ride height to weld on your spring mount or just leave the frame where it is and drop the mount 2" down from where the spring is now at rest. I hope this helps. Just my $.02
