1930 Model A truck build
A Truck
Ok been a while since truck has gotten any work done, has been a busy summer land race car got new engine 4.8 ls style motor new t10 trans new headers ect. Here's a picture of new motor.
    118 KB
A Truck
So started back on truck and after epic fail on cowl patch panel were moving along again.
    161 KB
A Truck
Installed and repaired passenger side but didn't snap a picture. This panel didn't need a lower patch, but had to repair top next to tank. Also still haven't found a good drivers side door so using the one from our sedan gasser for some inspiration, and to fit patch panels.
    110.8 KB
I can't remember everything, that's what computers are for...
I've seen front shocks mounted to split wishbones but I can't recall seeing them mounted to hairpins.
I would think that it would require some sort of plate between the upper and lower arms on the hairpin for structural support.
Lets see what anyone else has to say.
Build is looking great.
Torchie.
Didn't OldIron mount shocks on Indian head gussets in his hairpins?
Or was that Bonehead with bandito gussets?
Regardless, I thought I had seen shocks on hairpins with gussets on here before as well, Torchie.
-Chaz
Found it!
Got to do a little work today
Here's where the chief heads reside now as lower shock mounts
attachment.php
Here's how I mounted the shocks to the frame
Just enough clearance not to rub or bind :)
attachment.php
Everything is all painted and reassembled
attachment.php
I've got a little more rust patch work to do today then tomorrow I'll get some Chassis Saver for the underneath of the body.
At that point I can mount the body to the frame finally [dr
I'll have the engine day after tomorrow and will post pics :D
1933 Pontiac
Specific post
Woo Hoo!
-Chaz
Model a truck
Thanks for the tip on the front shocks looks like what I need to do, will be a bit before I get to it. Trying to stay on body work floors and transmission tunnel before any other stuff.
A truck
Finally front shock mounts again thanks for the tips. I used 1/4 plate over kill but what I had on hand.
    93 KB
A truck
Floors mostly done, started on steering column and pedals.
    97.5 KB
A truck
Thanks Old Iron. Last one for a bit, chopped up a drive shaft for it ran a few brake lines, made drive shaft loop. Floors and body are welded to frame.
    103.5 KB
Model a truck
Was thinking about filling roof and had a junk hood of a 1999 gmc, so cut it up and looks like it will work. I think it is had to tell until you weld it.
    84.6 KB
A truck
Here it is on truck. Hard to tell from picture but rear seam is were it always seems to be the most problem, or takes the most filler.
    101.7 KB
Model a
Ran out of c25 so taking break on roof. Dragged bed inside looks rough but going to try to make it work.
    90 KB
