I have posted other threads on the sedan. I'll post a few early pics of the build. The car is all owner built with very low budget. The top is chopped 2 1/2" and the body has been chopped 4 1/2". It has a 1958 332 Ford engine(first FE=390).It has a ford truck rear end and front brakes. 16" wheels with 1942 hubcaps and coker 6.00 16 front and 7.50 16 on rear. I made the frame and the zoomies. It has a 1918 10 gallon gas tank. It'll have 1928 head lights and tail lights. It has a 1939 chevy radiator with a late model 2 speed fan. I've been on this project a little over a year so it won't be long now! Can't wait!
Thanks Mobart! Took a while to figure out the grill location. I've made the grill adjustable, with about an inch up or down and in or out. Trying to keep everything older than the 58 engine but with the angle of the grill I figured I better use an Explorer fan. The shroud fit almost perfectly with some minor trimming plus it's 2 speed which will help up long hills and cruising town. Pitching the neck up on the grill now to be flat with the cowl.
Does anyone have a clue what this shifter is and what it came in? I think it's an after market but I'm not sure. There's no markings on it anywhere. I made the cable bracket on the back and the shift cam for a Ford-o-matic. The knob pulls down instaed of the tee pulling up. Thanks for any feed back!
