Going to post this here and in my build thread, just for those who are following.
Got the projectors today.
So here we go.
These are Bi-xenon projectors, tho I'll be using halogen bulbs in them. H1 bulbs to be exact.
Those who aren't familiar with bi projectors, they use a single filament bulb, and when you flip on the high beams, a small shield flips up.
The sheild is what creates the cutoff to aid in blinding passing cars.
You can see this feature work on projectors when you are approaching a car, typically one up a hill slightly, and their ungodly bright lights make you want to stab your eyeballs out with a sword. And about the moment to can't take it anymore, and you reach for the high beam switch on your car to tell the moron he's not the only one on the road, BAM! Their lights go dim.
Usually this isn't them realizing that you pay taxes too, that's the transition from below their beam cutoff, to above it. It's usually a pretty sharp line.
I opted to use these just because it's easier to make high beams work with one bulb.
I had to drill a 7/8" hole to mount the projector.
I installed it temporally in the houseing and found I was about 3/8" shy of being able to install the original glass and ring.
I was planning on buying some brass tube and plate and tig brazing the extension on, but with only 1/2", I figured I could work with that.
I ended up drilling the hole out to 1 1/2" to let the back of the housing project slightly out of the reflector.
Then made a 1/2" thick spacer to mount the projector.
All buttoned up, here is the result. This is one headlight. Drivers side isn't started yet.
Low beam (note the cutoff).
High beam (with cutoff sheild removed.)
I'm stuck a bit now as the overall girth of the projector housing has blocked a lot of the amber park/turn lighting. However, the pattern in the original glass makes for a nice wide bright illumination. Here's a quick video.
I think I'll add another bulb holder on the bottom of the reflector for an additional park/turn light.
It's VERY easy to see with the headlights on, and don't thing visiability will be any issue at all.
https://youtu.be/UoH7kLRvXNc
