CORPO
Buildin' it his way, one piece at a time...
thanks smallfoot!
Well I rewired the switches, and now they all work as they should. Finally got around to hooking up the brake light switch, although it needs to be adjusted a bit. The lights are only turning on when I really push the brakes hard. Dad Also made a plate to mount my license plate too, the bracket I have is a small bolt pattern, I think it may have been for a motorcycle plate.
So a few problems sorted.. and now some new ones! I decided it was time to stretch its legs a bit now that i had brake lights and plates. Unfortunately I did not get very far. I finally left the neighborhood and got halfway down the street before it was struggling to get gas... [S It would stall and then fire right back up. The only thing that I have changed since I have been doing laps in the neighborhood, is the return spring on the carb...... so I dont see how this would have caused my problems
I guess I will change it back... just to rule it out
Then I will probably disconnect my fuel line and make sure it is pumping properly..
If it is, bypass my my glas bowl fuel filter and go straight to the carb to see if it restricting the flow too much.
otherwise maybe the (new) electric pump is already dying..
It was a big disappointment. Mom and dad were in the chase vehicle and the fiance was in the passenger seat.. we were going to make a run to get some ice cream.. I made it to the first neighborhood down the street.. turned around and came home. On the bright side the old gal didn't leave me on the side of the road..
now that the switches are working.. heres a few of her laid out..
still progressing forward ... thanks guys
![](https://proxy.imagearchive.com/b57/b5752383619fa2667d3e2d9d77dcb7ca.jpg)
![](https://proxy.imagearchive.com/545/545e565a5c5981ee3678a4071a1a443b.jpg)
![](https://proxy.imagearchive.com/881/8810797d6617ff65778696ead9944598.jpg)
