frustration level rising
Ugh.
can't get the brakes working right. spongy pedal.
questioning the master cylinder. or the adjustable proportioning valve?
I used a master cylinder from Speedway. residual valves on the front(2psi) and rear (10psi) and a adjustable prop. valve on the rear.
I am running the unmolested 1978 Dodge motorhome brakes.
Very frustrated- I've bled the brakes 4x over. and the pedal is still soft. I'm suspecting either an air lock in the adjustable proportioning valve. ??
or a problem with the master cylinder. I'm thinking I may need to replace it. ??
it's new, but I could have messed it up installing it.
AND, the electric fan is not working. It turns on usually for a few seconds and then shuts off. I have it on a fuse. 20 amp i think. it's not blowing the fuse. Maybe a loose connection. the ground is solid.
Oh, and it won't start now.
Anyone want to buy a nearly done rat rod??
