1952B3b23
Good to hear that you got it running again.
Is .020 a factory gap spec as I usually set my points at .016 ?
That is for SBC and your Plymouth may be different.
Yea .020" is the factory spec.
Good to hear you got it figured out![cl You may have set the gap at 20 to start with, but you might not have had the distributor shaft in the right position to start with. It has to be turned where the highest part of the cam has the points fully opened. If you had it on one of the flats, the extra would have come when the cam separated the contacts of the points...
Good to see you back at it Chris.
Do you have any pics of the manifold so we can see a before and after?
All of my experience with Nicson parts is related to boat engines.
Looking forward to the pics after it's split.
[P [P [P
WOW! You've really started making some progress...looking good.
When i removed the intake/exhaust manifold i had one of the threaded studs snap off in the block. I got lucky that all of the others actually came out. To take it out i wanted to try welding a washer and nut to the end and then turning it out. I was paranoid that i would catch the car on fire with my MIG welder so i removed the fuel pump and covered as much as i could with fiberglass blankets. I first tried welding just a nut onto the end of the stud with the MIG. This didn't work, the nut broke off
For round two i decided to use my TIG welder. But for that i had to remove the passenger side fender so i could reach in and actually see what i was doing. This worked great. The tig allows you to get really good penetration and it heats up the stud a lot too. So while it was still hot i squirted a little penetrating oil on it and was able to remove it without a problem. Also, the TIG doesn't produce any flying sparks so i wasn't all nervous that i'd light something off.
Having the fender off will help with routing the dual exhaust and fuel lines. It's a lot easier then slumping over the fender for hours!
Thanks for looking,
-Chris
