no prob!
I REEEEEEEEEALLY didnt want to do rust repair and I figured the sure way to make me do it was to beauty up the cab a little. I didnt like that it was more rust than paint, I dont mind rust but it was like 80% and more than that after pressure washing. I found a green (charleston green) that was really close to the original juniper green, but it didnt really look close when I put it on, and when I sanded it the blue in the juniper green really started to show.
I watched some patina videos and didnt really like what I saw, painting the whole truck several times. I decided to break down what was wrong with the charleston green and make a plan to fix it. I ignored flash times and laid down a wet black, a wet navy blue, a wet hunter green, and then topped with the wet charleston green. it was really runny and thick, I was aiming to let it mix as a miasma instead of distinct layers, knowing I was going to sand it back.
IMG_7724 by
Joe Doh, on Flickr
I sanded it back with some 120 grit then some 320 when I started seeing color
53223155830__2C23AA26-CC3B-4F22-A369-619E15EF3D8C-1 by
Joe Doh, on Flickr
I like it. the door is the original color and I think after some wet sanding I will be there.
so today I started on the floor. my temp brace was still holding so I cut back to good steel and started by making the brace for between the door jambs and mocking up the first floor piece
IMG_7725 by
Joe Doh, on Flickr
one brace wasnt going to cut it for the seats, so I added some support.
IMG_7728 by
Joe Doh, on Flickr
I drilled a million holes, going for the monocoque strength tie to the original cross bar and floor.
IMG_7729 by
Joe Doh, on Flickr
IMG_7731 by
Joe Doh, on Flickr
so tomorrow I will get some pipe for a pass through of the rear body mounts and make a tie in to the back wall. I over lapped the pieces in the center so its already super strong, gonna be stronger, without adding a bunch of useless tube.
supposed to rain a bunch tommorrow, maybe I will have it back on the frame and working the pedals. maybe
