RAT IHC
Troy,
I have different spindle brackets coming that are a inch longer because of a limited turning radius when cross bar hits the bat wings. Hadn't thought about a panard though because the mono spring is jamed between the bat wings but prob should have one for alinement? The steering link is level with the ground but it doesn't bind going from side to side.[S
Some people don't use a panhard bar with cross steer, but in my experience and knowledge about it the spring isn't meant to keep things centered...only to absorb bumps and stuff. I'm not sure if the angle of the steering arm will cause a problem or not...I'm going to look through some of my stuff at home tonight...if I find anything I'll let you know. I've always been taught that the steering should only be on a slight angle from the draglink...but never "why"...I'll try to confirm tonight.
Maybe someone else has some input on it?
-Troy
