dogpatch1
the ones in my scrap pile are 5lugs x 7 inch bolt pattern. off a 1945 1.5 ton. dp1
thats gonna be a sweet ride!
my buddy glen has a 46 1.5er going under the knife on killbillet.
Thank you. Im now in the prosess of designing an air ride set up for the front.i will be using the above axle,removing the leafs completely and using radius rods.mounting the bags on the spring pads then fabricating the upper frame brackets.the thing thats got me now is im gonna need some sort of panhard bar.....the other problem i see is steering,can i swap the left spindle to the right and vice versa to put the steering in front of the axle? Comments? Suggestions?
....LOLOLYes you can but it won't handle as well and if you bump ANYTHING with the Tie Rod guess what happens. I also DO IT all the time so what do I know,.............lol
ok,....but what changes the "handling" characteristics? the "solid axle" is new to me so sorry for the dumb questions..LOL
i think i understand...the spindles are angled back a lil bit and when we swap them they we screw up the pitch......am i on the right track?
Gotcha....looks like iv got alot of planing to do.Like I said I have no Idea what or why and It does not make it undriveable so I just run it if I have to. If I don't have to I avoid it and put the tie rod to the rear of the axle.
hey p.k., here are some pics on ackerman angle and how it is set up, mainly it is in relation to your front tires on turns, to eliminate whats known as scrubbing where one tire will drag the other thru a turn, as seen the inside tire turning radius will be smaller than the outside tire on a giving turn. running your spindles either way can be done its your call. and millions of guys flip em, there are some angels to help prevent bump steer if your going with a "side" steer (traditional but with flipped spindles) setup as opossed to cross steer also. hope this helps, george. dp1
that why i love this site, so much info!!!!!! rev tex <<<<<<< info junkie
