[P [P [P
Thanks guys - and to answer your question Doc, no I haven't completely solved the steering connection. I'm working on that right now, and it's going to be an interesting one. I'm trying not to modify those headers, but I may have to.
Just hoping to help, if it helps you at all...
On our '37 coupe project, we mounted the small block as low and as far back as possible, which put the (ceramic coated) header tube in harm's way. [S
My solution was to recess the column 3", giving necessary clearance, acceptable joint angles and "work around" the header, though still quite tight and snuggly.
If you haven't discovered this already, Sweet Mfg. makes high quality (Made In USA) joints without Borgeson/Flaming River price and polish. I believe Speedway provided the joints we're using... regardless, they're excellent quality and saved some money where pretty polished SS isn't needed or required...
