Truck is getting there slowly.
that is really cool how hard is it to convert from gasoline to propane? i have been watching this build for a while it is cool to see it come along. again that is good work.
Nice job, looks like would be a nice hauler to pull my 24' enclosed trailer to swap meets.
wendle; [IMG said:http://i16.photobucket.com/albums/b18/wendleburger/Dodge%20Build/dodge14.jpg[/IMG]
Thats one tough tow truck!!! Would be awesome to see at any rock crawlin event. Good work and showin that here in aus we can still build rats liek the rest of them!
Hi Wendle
I have been inspired by watching your pilothouse build to join this forum. I'm another Aussie pilothouse owner located in Victoria. Loved the look of your truck after the chassis swap, really liked the idea as a way to modernise the running gear. haven't had time to look into doing something similar to mine, however that might be much more difficult as I have the full ute back. Look forward to your thoughts
Latch
If my truck started out as nice as yours there is no way I would have gone down the path I have with it.
The chassis on mine was toast, so I just used the method that is easiest for rego.
Your truck is really nice man.
Got some of my wiring done, I drove it for the first time last weekend.
Not much left to do now.
Thanks for your comments. looks can deceive though. I've got big problems with rust and suspension that I need to sort out, but this will happen as funds permit. Can't wait to see and hear your truck in action, hope you post a small video of the big launch day.
Latch
If the chassis is still good and solid maybe look at 1990's Falcon's for a donor?
I believe the front end of them comes out in one piece with the wishbones and rack without any cutting? If you can pick up a wagon or ute you should be able to get a good rear end out of the deal with the same stud pattern.
Rust is pretty easy to deal with in these cabs. Everything apart from the dash and the bonnet parts seems to be at least 16-gauge, so it's all pretty easy to weld and work with.
Good luck with it, I'd really like to find another one the same size as yours and do a bit of a modification project, rather than a remove/replace project like this one.
Got any more pics of yours?
[ddev
That thing sounds badass
