Started to get ready for the chop. I removed the wind shield and rear window. I'm going to remove the cab brace that goes across the bottom of the rear window on a temporary basis. The four inch chop I'm going to attempt will line up behind the brace so it comes out till the final welding is done then goes back in. You can see the welds removed in picture four.
Four inch chop following the body line. The rear of the cab will slide down inside along the chalk line. Curved cut to eliminate some heat pucker.
I am going to keep the rear window the original size. Some don't like that look, but it gives easy rear view for an old mans stiff neck.
The A-pillar will get the same treatment Torchie did on his with a little twist. I'm going to undo a few spot welds on the header and cut around the visor mount to get my A-pillar to pull out. See chalk lines.
Thanks for the tips on the A-pillar treatment Torchie. You can see from the pictures my intended cuts at the top of the A-pillar. The header treatment and outer cut will make it easier to repair the header. I hope.[S
One question from a rookie. the A-pillar gets cut at 90* to the A-pillar, right? Straight cut, not at an angle. Perpendicular to the pillar. Is that right?
The last three pictures are a repair technique I have never seen before. Done by previous owner. A gob of Bondo with a piece of galvanized metal stuck into it to cover a hole[S The galvanization makes the piece pop right off, It don't stick. Got some clean and weld to do. [
