Im not 100% sure on exactly what is used but I do know that the calipers are GM from an 71-76 impala. So i guessing that it may be the same kit. Kits is super easy to put on. No special tools. Instead of a press to put the spindle spacer on. I used a 2" metal pipe and a hammer. It worked perfectly. Cant wait to get the master cylinder on so I can test them out!
ya true. I did shop around but this seemed like the best for me since I wanted to replace the entire drum system an needed an entire kit.
Where did you get brake kit from
got mine from speedwaymotors. It came with everything I needed. Nothing was spared. It comes with Brackets, rotors, bearings, seals, bolts, calipers, pads, new brake lines. There was nothing left out and for a damn good price. I like it bc i didnt have to go source calipers or rotors like some kits make you do. Every was there and bolted up.
