Old Iron
Wasn't meMr Torchie- Who have you been talking to on RRR[
Glad you found the door problem.
If you hadn't went to that engineering course you'd of never found it.
Hey Torchie, how do you think your door windows will be effected? Will you still be able to put them up and down after leaning the door tops in. The question might be a little premature, but I'm dying to know.
My grill has progresses nicely, and I'm getting excited about chopping the roof.![]()
The only door glass you should have to replace or modify is the vent window. The main door window should remain the same. The top of the A pillar moves forward as it moves down, but the door opening width won't change. So the top of the door will also move forward as it moves down. Save the pieces you cut out. They should be able to fill the top gap.
I'm glad to hear that your windows should still function. [cl
I was wondering how the wing window thing worked on a chop. Im still working on buying a 50 Ford cab from a farmer that doesnt need the money or the truck. He just keeps dragging his feet. So I am going to start on a 31 Dodge Sedan turned pickup cab. I have been watching your build and seeing a lot of good stuff. Looking forward to pics of your windows
Wing window needs to be reshaped. I'm going to try and do mine on a belt sander with fine grit. Tape it all up with masking tape first. card board for pattern. Transfer template to tape and then grind. Then you gotta reshape the frame for the vent glass as well.
Torchie, it's funny how the brain can play little tricks on us. I'm also doing some mental engineering on my Jeep. It goes into terminal death wobble on the same bump every day. [S Darned if I can find the flaw causing it. It's slightly modified and front end shops just start throwing parts at it that don't require replacing. I think ill leave it for tomorrow.
Hey Mike,
Tell us more about the flat spot. I imagine it is where the fill piece gets welded in. Does the glass need to be reshaped to match the flat sot, or can the flat spot be massaged out?
I used a 3x21" belt sander and squirt bottle with water to keep the glass cool.
It creates a mess but, so does everything else in hot rodding.
You can buy belts on line that are made to grind glass and be wet at the same time. 10 belts for 10 bucks
Here's where I got mine : http://www.sandinghouse.com/List/Sanding-Belts-For-Glass-and-Mirror
On my 40 Pontiac chop, I used an oxygen/acetylene torch, heated the inside curve of the wing vent frame and bent as needed to fit the shape of the opening. Relocated the upper pivot to line up with the bottom pivot, ground the glass and the wing vents work fine.
Torchie Looks like your thread is on info overload. Old Iron has right idea and also the easiest. Once your window is back in with the window track (you have to modify the window track) you can make a pattern of the opening then start heating and reshaping. The other route is cut it up and weld it back together.
Torchie You can retain your Diploma from What'samatta U.
