soltz
The Rat Captain
Torchie i learn a while back to take a picture of things before disassembling ![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It'll get there and you 'll be driving before you know it. [cl
Check, check, and triple check! We're not as sharp as we used to be, so being extra careful is a good thing. It takes a lot less time to make sure things are right than to deal with the aftermath when they are wrong.![]()
I hope so soltz. Now that I have the brake shoes put back in the right way.
Went back out last night to finish buttoning up the other side and realized that I had the brake shoes on backwards.The short shoe should be on the backside of the drum.
I have got to admit to being frustrated about this. Lately things that I have been doing for 40 years I am now screwing up.
Well they are right now.
Thanks for visiting.....
I'm educated enough to know that when I start guessing, I'll probably be wrong!
Motor, tranny, fenders, hood, etc. should bring it down some but if you're looking for lower, you'll just have to wait and see how much of a change you'll need to fabricate in. Looking good! What are your expectations for the stance on this Torchie?
Torchie, you asked for guesses on how much your truck will drop when you add the motor and transmission. I'm pretty sure mine dropped 2" when I set my Baby Hemi in and it should weigh about the same as that Rocket. Our suspensions are not nearly the same though.
Great reading.Here is a link to engine weights.
We are talking about a nearly 100lb difference between the stock Ford flatty and the Olds.
The Hemi is heavier than either of those Mac.
Not that any of this matters at this point as once I get the Olds engine and the Ford trans back in I will know for sure. Just kind of wondering.......[S
http://www.35pickup.com/mulligan/weight.txt
Master cylinder looks awesome!!!!!!!!!!!
Did they comment on what they thought started the fires?
Great work on the master cylinder....
Never a dull moment in your neck of the woods![]()
