Old Iron
[cl[cl[cl
[P[P[P
[P[P[P
You might be better off to just do an engine/transmission swap, and maybe rear end.
There is a guy near here that did much the same thing on a truck that model, he used the engine and rear from a bus, but he put it behind the cab and put a box sleeper over it. But his is a ramp truck, not a dump. As far as I know, he kept the stock front axle, but bought some one piece wheels off an import truck.
I watched the videos.
Can you channel the truck cab to lower it down on the frame more?
But then that presents the issue of the dump bed doesn't it.
And what about using the front fenders (Or parts of them) from the bus on the truck?
You can shorten Solid front axels but it may affect your turn radius and doesn't solve the wide rear end either.
Just spitballing here. It's kind of hard to get a handle on things with out being there looking at them both.
[P [P [P
I’m actually quite surprised at how many folks suggest a change of plans by not using one of the busses.
Other than a couple oddball measurements and pto adaptation issues, I’m not really seeing anything that screams stop.
